Rockwell Automation Analytics LogixAI
Sep 9, 2025, 4:46 PM UTC
  • ATTENTION: Exploitable from an adjacent network/low attack complexity
  • Equipment: Analytics LogixAI
  • Vulnerability: Exposure of Sensitive System Information to an Unauthorized Control Sphere
Successful exploitation of this vulnerability could allow an attacker to access sensitive information.
The following versions of Rockwell Automation Analytics LogixAI are affected:
  • Analytics LogixAI: Versions 3.00 and 3.01
3.2.1 EXPOSURE OF SENSITIVE SYSTEM INFORMATION TO AN UNAUTHORIZED CONTROL SPHERE CWE-497
An open database issue exists in the affected product and version. The security issue stems from an over permissive Redis instance. This could result in an attacker on the intranet accessing sensitive data and potential alteration of data.
CVE-2025-9364 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9364. A base score of 8.7 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation released a product update addressing this vulnerability:
Users of the affected software unable to upgrade to one of the corrected versions should use Rockwell Automation's security best practices.
  • September 9, 2025: Initial Republication of Rockwell Automation advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-252-08
