Delta Electronics DIALink
Sep 16, 2025, 4:36 PM UTC
  • CVSS v4 10.0
  • Vendor: Delta Electronics
  • Equipment: DIALink
  • Vulnerabilities: Path Traversal
Successful exploitation of these vulnerabilities could allow an attacker to bypass authentication.
The following versions of Delta Electronics DIALink are affected:
  • DIALink: Versions V1.6.0.0 and prior
3.2.1 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
Delta Electronics DIALink has an Improper Limitation of a Pathname to a Restricted Directory vulnerability which could allow an attacker to bypass authentication.
CVE-2025-58320 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.3 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2025-58320. A base score of 6.9 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:L/VI:L/VA:L/SC:N/SI:N/SA:N).
3.2.2 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
CVE-2025-58321 has been assigned to this vulnerability. A CVSS v3.1 base score of 10 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-58321. A base score of 10 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
An anonymous researcher working with Trend Micro's Zero Day Initiative reported these vulnerabilities to CISA.
Delta Electronics recommends users to download and upgrade to DIALink v1.8.0.0 or later. The latest version can be found at the Delta Download Center.
Delta Electronics has the following general recommendations for users to follow:
  • Don't click on untrusted Internet links or open unsolicited attachments in emails.
  • Place systems and devices behind a firewall and isolate them from the business network.
Users are encouraged to see Delta-PCSA-2025-00016_DIALink for more information.
For more information, contact Delta Electronics.
  • September 16, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-259-07
