- CVSS v3 9.8
- Vendor: Siemens
- Equipment: RUGGEDCOM, SINEC NMS, and SINEMA
- Vulnerabilities: NULL Pointer Dereference, Out-of-bounds Write, Server-Side Request Forgery (SSRF)
Successful exploitation of these vulnerabilities could allow an attacker to cause a denial-of-service, crash the product, or perform remote code execution.
- Siemens RUGGEDCOM NMS: All versions when using the device firmware upgrade mechanism (CVE-2021-34798)
- Siemens SINEC NMS: < V1.0.3
- Siemens SINEMA Remote Connect Server: < V3.1 (CVE-2021-34798)
- Siemens SINEMA Server V14: All versions
3.2.1 NULL POINTER DEREFERENCE CWE-476
Malformed requests may cause the server to dereference a NULL pointer. This issue affects Apache HTTP Server 2.4.48 and earlier.
CVE-2021-34798 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
ap_escape_quotes() may write beyond the end of a buffer when given malicious input. No included modules pass untrusted data to these functions, but third-party / external modules may. This issue affects Apache HTTP Server 2.4.48 and earlier.
CVE-2021-39275 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
3.2.3 SERVER-SIDE REQUEST FORGERY (SSRF) CWE-918
A crafted request uri-path can cause mod_proxy to forward the request to an origin server chosen by the remote user. This issue affects Apache HTTP Server 2.4.48 and earlier.
CVE-2021-40438 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.0 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:C/C:H/I:H/A:H).
Siemens ProductCERT reported these vulnerabilities to CISA.
- SINEC NMS: Update to V1.0.3 or later version
- (CVE-2021-34798) All affected products: Restrict access to the affected systems, especially to port 443/tcp, to trusted IP addresses only
- (CVE-2021-34798) RUGGEDCOM NMS, SINEMA Server V14: Currently no fix is planned
- (CVE-2021-34798) SINEMA Remote Connect Server: Update to V3.1 or later version
- (CVE-2021-39275, CVE-2021-40438) SINEC NMS, SINEMA Server V14: Restrict access to the affected systems, especially to port 443/tcp, to trusted IP addresses only
- (CVE-2021-39275, CVE-2021-40438) SINEMA Server V14: Currently no fix is planned
For more information see the associated Siemens security advisory SSA-685781 in HTML and CSAF.
- September 16, 2025: Initial Republication of Siemens ProductCERT SSA-685781
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-259-04
