Raise3D Pro2 Series 3D Printers
  • CVSS v4 8.8
  • Vendor: Raise3D
  • Equipment: Pro2 Series
  • Vulnerability: Authentication Bypass Using an Alternate Path or Channel
Successful exploitation of this vulnerability could result in data exfiltration and compromise of the target device.
The following firmware versions of the Rasie3D Pro2 Series printers are affected:
  • Pro2 Series: All Versions
3.2.1 AUTHENTICATION BYPASS USING AN ALTERNATE PATH OR CHANNEL CWE-288
An unauthenticated debug port may allow access to the device file system.
CVE-2025-10653 has been assigned to this vulnerability. A CVSS v3 base score of 8.6 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:L/A:L).
A CVSS v4 score has also been calculated for CVE-2025-10653. A base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:L/VA:L/SC:N/SI:N/SA:N).
Souvik Kandar reported this vulnerability to CISA.
Raise3D confirmed this vulnerability exists in the Pro2 Series devices when developer mode is enabled. Raise3D is developing a patched version of the printer firmware; however, no release date has yet been provided.
Raise3D recommends disabling developer mode if it is not required. Further information is available from Raise3D at the Raise3D Support Center
  • October 02, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-275-01
