- CVSS v4 6.8
- Vendor: Delta Electronics
- Equipment: DIAScreen
- Vulnerabilities: Out-of-bounds Write
Successful exploitation of these vulnerabilities could allow an attacker to write data outside of the allocated memory buffer.
The following versions of Delta Electronics DIAScreen are affected:
- DIAScreen: Version 1.6.0 and prior
Delta Electronics DIAScreen can write data outside of the intended memory buffer when a valid user opens a maliciously crafted project file.
CVE-2025-59297 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:L/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-59297. A base score of 6.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:A/VC:L/VI:L/VA:H/SC:N/SI:N/SA:N).
CVE-2025-59298 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:L/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-59298. A base score of 6.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:A/VC:L/VI:L/VA:H/SC:N/SI:N/SA:N).
3.2.3 OUT-OF-BOUNDS WRITE CWE-787
CVE-2025-59299 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:L/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-59299. A base score of 6.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:A/VC:L/VI:L/VA:H/SC:N/SI:N/SA:N).
3.2.4 OUT-OF-BOUNDS WRITE CWE-787
CVE-2025-59300 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.6 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:L/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-59300. A base score of 6.8 has been calculated; the CVSS vector string is (CVSS:4.0/AV:L/AC:L/AT:N/PR:N/UI:A/VC:L/VI:L/VA:H/SC:N/SI:N/SA:N).
- CRITICAL INFRASTRUCTURE SECTORS: Energy
- COMPANY HEADQUARTERS LOCATION: Taiwan
Natnael Samson, working with Trend Micro Zero Day Initiative, reported these vulnerabilities to CISA.
Delta Electronics has released v1.6.1 of DIAScreen and recommends users install this update on all affected systems.
For more information, see Delta Electronics' advisory Delta-PCSA-2025-00018.
CISA recommends users take the following measures to protect themselves from social engineering attacks:
- October 7, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-280-01
