Hitachi Energy Asset Suite
Oct 9, 2025, 4:23 PM UTC
  • CVSS v4 6.0
  • Vendor: Hitachi Energy
  • Equipment: Asset Suite
  • Vulnerability: Improper Output Neutralization for Logs
Successful exploitation of this vulnerability could result in the manipulation of content or the injection of data with the potential of carrying out further malicious attacks.
The following versions of Asset Suite are affected:
  • Asset Suite: Versions 9.7 and prior
3.2.1 IMPROPER OUTPUT NEUTRALIZATION FOR LOGS CWE-117
A vulnerability exists in Asset Suite for an authenticated user to manipulate the content of performance related log data or to inject crafted data in logfile for potentially carrying out further malicious attacks. Performance logging is typically enabled for troubleshooting purposes while resolving application performance related issues.
CVE-2025-10217 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:H/A:N).
A CVSS v4 score has also been calculated for CVE-2025-10217. A base score of 6.0 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:P/PR:L/UI:N/VC:N/VI:H/VA:N/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: Switzerland
Hitachi Energy PSIRT reported this vulnerability to CISA.
Hitachi Energy recommends users disable performance logging and apply the update as soon as it becomes available.
Hitachi Energy recommends the following security practices and firewall configurations to help protect a process control network from attacks originating from outside the network. Such practices include ensuring process control systems are physically protected from direct access by unauthorized personnel, have no direct connections to the Internet, and are separated from other networks by means of a firewall system with a minimal number of exposed ports, and others to be evaluated case by case. Process control systems should not be used for Internet surfing, instant messaging, or receiving e-mails. Portable computers and removable storage media should be carefully scanned for viruses before they are connected to a control system. Proper password policies and processes should be followed.
For more information see the associated Hitachi Energy PSIRT security advisory Log Data Vulnerability in Hitachi Energy Asset Suite Product.
  • October 9, 2025: Initial Republication of Hitachi Energy PSIRT 8DBD000226
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-282-01
