Rockwell Automation Stratix
Oct 9, 2025, 4:23 PM UTC
  • CVSS v4 6.3
  • Equipment: Stratix 5700, 5400, 5410, 5200, 5800
Successful exploitation of this vulnerability could result in arbitrary code execution.
The following version of Stratix 5700 is affected:
  • Stratix 5700: Version v15.2(8)E7 and prior
  • Stratix 5400: Version v15.2(8)E7 and prior
  • Stratix 5410: Version v15.2(8)E7 and prior
  • Stratix 5200: Version v17.17.01 and prior
  • Stratix 5800: Version v17.17.01 and prior
A third-party vulnerability exists in the affected products. The affected products use Cisco IOS XE Software which contains a vulnerability in the Simple Network Management Protocol (SNMP) subsystem. An authenticated, remote attacker with low privileges could cause a denial-of-Service (DoS) condition on an affected device running Cisco IOS Software or Cisco IOS XE Software. To cause the DoS, the attacker must have the SNMPv2c or earlier read-only community string or valid SNMPv3 user credentials. An authenticated, remote attacker with high privileges could execute code as the root user on an affected device running Cisco IOS XE Software. To execute code as the root user, the attacker must have the SNMPv1 or v2c read-only community string or valid SNMPv3 user credentials and administrative or privilege 15 credentials on the affected device. An attacker could exploit this vulnerability by sending a crafted SNMP packet to an affected device over IPv4 or IPv6 networks. This vulnerability is due to a stack overflow condition in the SNMP subsystem of the affected software. A successful exploit could allow a low-privileged attacker to cause the affected system to reload, resulting in a DoS condition, or allow a high-privileged attacker to execute arbitrary code as the root user and obtain full control of the affected system.
CVE-2025-20352 has been assigned to this vulnerability. A CVSS v3 base score of 7.7 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:C/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-20352. A base score of 6.3 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:N/SC:N/SI:N/SA:H).
Rockwell Automation recommends users of the affected Stratix software implement workarounds from Cisco and our security best practices.
For more information about this issue, see the advisory on the Rockwell Automation security page.
  • October 09, 2025: Initial Republication of Rockwell Automation advisory SD1749
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-282-03
