Hitachi Energy MACH GWS
Oct 16, 2025, 4:34 PM UTC
  • CVSS v4 7.1
  • Vendor: Hitachi Energy
  • Equipment: MACH GWS
  • Vulnerabilities: Incorrect Default Permissions, Improper Validation of Integrity Check Value, Improper Certificate Validation
Exploiting these vulnerabilities could allow an attacker to tamper with system files, cause a denial of service, or perform a remote man-in-the-middle attack.
The following versions of MACH GWS affected:
  • MACH GWS: Versions 3.0.0.0 to 3.4.0.0
3.2.1 INCORRECT DEFAULT PERMISSIONS CWE-276
A vulnerability exists in MACH GWS product, which if exploited, could allow a local unauthenticated attacker to tamper a system file resulting in a denial of notify service.
CVE-2025-39201 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.1 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:U/C:N/I:L/A:H).
A CVSS v4 score has also been calculated for CVE-2025-39201. A base score of 6.9 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:L/UI:N/VC:N/VI:L/VA:H/SC:N/SI:N/SA:L).
3.2.2 IMPROPER VALIDATION OF INTEGRITY CHECK VALUE CWE-354
A vulnerability exists in the IEC 61850 of the MACH GWS product where an IEC 61850-8 crafted message content from IED or remote system can cause a denial of service resulting in disconnection loop.
CVE-2025-39203 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-39203. A base score of 7.1 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.3 IMPROPER CERTIFICATE VALIDATION CWE-295
A vulnerability exists in the IEC 61850 in MACH GWS product where the certificate validation of the TLS protocol allows a remote man-in-the-middle attack due to missing proper validation.
CVE-2025-39205 has been assigned to this vulnerability. A CVSS v3.1 base score of 6.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-39205. A base score of 7.1 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
  • COMPANY HEADQUARTERS LOCATION: Switzerland
Hitachi Energy PSIRT reported these vulnerabilities to CISA.
Hitachi Energy recommends users update to Version 3.5 at the earliest.
Hitachi Energy recommends the following security practices and firewall configurations to help protect a process control network from attacks that originate from outside the network. Such practices include ensuring that process control systems are physically protected from direct access by unauthorized personnel, have no direct connections to the Internet, and are separated from other networks by means of a firewall system that has a minimal number of ports exposed, and others that have to be evaluated case by case. Process control systems should not be used for Internet surfing, instant messaging, or receiving e-mails. Portable computers and removable storage media should be carefully scanned for viruses before they are connected to a control system. Proper password policies and processes should be followed.
Hitachi Energy recommends users deploy the product following the "GWS deployment guideline" document. Users should maintain their systems with products running on supported versions and follow maintenance releases.
For more information see the associated Hitachi Energy PSIRT security advisory 8DBD000222 Multiple Vulnerabilities in Hitachi Energy MACH GWS Product.
  • October 16, 2025: Initial Republication of Hitachi Energy PSIRT 8DBD000222
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-289-11
