Siemens SIMATIC S7-1200 CPU V1/V2 Devices
Oct 21, 2025, 4:45 PM UTC
  • Equipment: SIMATIC S7-1200 CPU V1/V2 Devices
  • Vulnerabilities: Improper Input Validation, Authentication Bypass by Capture-replay
Successful exploitation of these vulnerabilities could allow an unauthenticated remote attacker to trigger functions by record and playback of legitimate network communication, or place the controller in stop/defect state by causing a communications error.
  • SIMATIC S7-1200 CPU V1 family (incl. SIPLUS variants): All versions before 2.0.3 (CVE-2011-20001)
  • SIMATIC S7-1200 CPU V1 family (incl. SIPLUS variants): All versions before 2.0.2 (CVE-2011-20002)
  • SIMATIC S7-1200 CPU V2 family (incl. SIPLUS variants): All versions before 2.0.3 (CVE-2011-20001)
  • SIMATIC S7-1200 CPU V2 family (incl. SIPLUS variants): All versions before 2.0.2 (CVE-2011-20002)
The web server interface of affected devices improperly processes incoming malformed HTTP traffic at high rate. This could allow an unauthenticated remote attacker to force the device entering the stop/defect state, thus creating a denial-of-service condition.
CVE-2011-20001 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2011-20001. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
3.2.2 AUTHENTICATION BYPASS BY CAPTURE-REPLAY CWE-294
Affected controllers are vulnerable to capture-replay in the communication with the engineering software. This could allow an on-path attacker between the engineering software and the controller to execute any previously recorded commands at a later time (e.g. set the controller to STOP), regardless whether or not the controller had a password configured.
CVE-2011-20002 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.4 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:H/PR:N/UI:N/S:U/C:N/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2011-20002. A base score of 8.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:P/PR:N/UI:N/VC:N/VI:H/VA:H/SC:N/SI:N/SA:N).
Dillon Beresford from NSS Labs reported these vulnerabilities to Siemens.
Artem Zinenko from Kaspersky recommended the inclusion of SIPLUS variants to Siemens.
Siemens has released new versions for the affected products and recommends updating to the latest versions:
  • (CVE-2011-20001): Disable the web server if possible
  • (CVE-2011-20001): Update to V2.0.3 or later version
  • (CVE-2011-20002): Update to V2.0.2 or later version
For more information see the associated Siemens security advisory SSA-625789 in HTML and CSAF.
  • October 21, 2025: Initial Republication of Siemens ProductCERT SSA-625789
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-294-03
