- CVSS v4 8.7
- Vendor: Rockwell Automation
- Equipment: Compact GuardLogix 5370
- Vulnerability: Uncaught Exception
Successful exploitation of this vulnerability could result in a denial-of-service.
The following versions of Compact GuardLogix 5370 are affected:
- Compact GuardLogix 5370: Version 30.012 and prior
3.2.1 UNCAUGHT EXCEPTION CWE-248
A denial-of-service security issue in the affected product. The security issue stems from a fault occurring when a crafted CIP unconnected explicit message is sent. This can result in a major non-recoverable fault.
CVE-2025-9124 has been assigned to this vulnerability. A CVSS v3 base score of 7.5 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-9124. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:N).
Rockwell Automation recommends users upgrade their devices to 30.14 or later.
Users of the affected software unable to upgrade to one of the corrected
versions should follow Rockwell Automation's security best practices.
- October 21, 2025: Initial Republication of Rockwell Automation advisory SD1755
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-294-02
