- CVSS v4 9.3
- Vendor: Rockwell Automation
- Equipment: Studio 5000 Simulation Interface
- Vulnerabilities: Improper Limitation of a Pathname to a Restricted Directory ('Path Traversal'), Server-Side Request Forgery (SSRF)
Successful exploitation of these vulnerabilities could allow attackers to trigger outbound SMB requests to capture NTLM hashes and execute scripts with Administrator privileges upon system reboot.
The following versions of Rockwell Automation Studio 5000 Simulation Interface are affected:
- Studio 5000 Simulation Interface: Version 2.02 and prior
3.2.1 IMPROPER LIMITATION OF A PATHNAME TO A RESTRICTED DIRECTORY ('PATH TRAVERSAL') CWE-22
A local code execution security issue exists within Studio 5000 Simulation Interface via the API. This vulnerability allows any Windows user on the system to extract files using path traversal sequences, resulting in execution of scripts with Administrator privileges on system reboot.
CVE-2025-11696 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11696. A base score of 9.3 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
3.2.2 SERVER-SIDE REQUEST FORGERY (SSRF) CWE-918
A local server-side request forgery (SSRF) security issue exists within Studio 5000 Simulation Interface via the API. This vulnerability allows any Windows user on the system to trigger outbound SMB requests, enabling the capture of NTLM hashes.
CVE-2025-11697 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (AV:L/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11697. A base score of 8.8 has been calculated; the CVSS vector string is (AV:L/AC:L/AT:P/PR:L/UI:N/VC:H/VI:H/VA:H/SC:H/SI:H/SA:H).
- CRITICAL INFRASTRUCTURE SECTORS: Chemical, Critical Manufacturing
Rockwell Automation recommends that users upgrade to version 3.0.0 or later.
Users who are unable to upgrade to the corrected version are encouraged to follow Rockwell Automation's security best practices.
- November 13, 2025: Initial republication of Rockwell Automation advisory 'Studio 5000 Simulation Interface - Multiple Vulnerabilities'
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-317-06
