Nov 18, 2025, 5:32 PM UTC
  • CVSS v4 9.3
  • Vendor: METZ CONNECT
  • Equipment: EWIO2
  • Vulnerabilities: Authentication Bypass by Primary Weakness, Improper Control of Filename for Include/Require Statement in PHP Program ('PHP Remote File Inclusion'), Unrestricted Upload of File with Dangerous Type, Path Traversal: '.../...//', Improper Access Control
Successful exploitation of these vulnerabilities could allow an attacker to bypass authentication and control the device remotely or perform remote code execution.
METZ CONNECT reports that the following products are affected:
  • METZ CONNECT Firmware (<2.2.0) installed on METZ CONNECT Hardware EWIO2-M: All versions
  • METZ CONNECT Firmware (<2.2.0) installed on METZ CONNECT Hardware EWIO2-M-BM: All versions
  • METZ CONNECT Firmware (<2.2.0) installed on METZ CONNECT Hardware EWIO2-BM: All versions
3.2 Vulnerability Overview
3.2.1 AUTHENTICATION BYPASS BY PRIMARY WEAKNESS CWE-305
The commissioning wizard on the affected devices does not validate if the device is already initialized. An unauthenticated remote attacker can construct POST requests to set root credentials.
CVE-2025-41733 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41733. A base score of 9.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 IMPROPER CONTROL OF FILENAME FOR INCLUDE/REQUIRE STATEMENT IN PHP PROGRAM ('PHP REMOTE FILE INCLUSION') CWE-98
An unauthenticated remote attacker can execute arbitrary PHP files and gain full access of the affected devices.
CVE-2025-41734 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41734. A base score of 9.3 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.3 UNRESTRICTED UPLOAD OF FILE WITH DANGEROUS TYPE CWE-434
A low privileged remote attacker can upload any file to an arbitrary location due to missing file check resulting in remote code execution.
CVE-2025-41735 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41735. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.4 PATH TRAVERSAL: '.../...//' CWE-35
A low privileged remote attacker can upload a new or overwrite an existing python script by using a path traversal of the target filename in PHP resulting in a remote code execution.
CVE-2025-41736 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-41736. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.5 IMPROPER ACCESS CONTROL CWE-284
Due to webserver misconfiguration an unauthenticated remote attacker is able to read the source of PHP modules.
CVE-2025-41737 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.5 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N).
A CVSS v4 score has also been calculated for CVE-2025-41737. A base score of 8.7 has been calculated; the CVSS vector string is (CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:N/VC:H/VI:N/VA:N/SC:N/SI:N/SA:N).
Noam Moshe and Tomer Goldschmidt of Claroty Team82 reported these vulnerabilities to CISA.
METZ CONNECT has identified the following specific workarounds and mitigations users can apply to reduce risk:
  • (Product Group: METZ CONNECT Firmware (<2.2.0) installed on METZ CONNECT Hardware EWIO2-M(All versions), METZ CONNECT Firmware (<2.2.0) installed on METZ CONNECT Hardware EWIO2-M-BM(All versions), METZ CONNECT Firmware (<2.2.0) installed on METZ CONNECT Hardware EWIO2-BM(All versions)): METZ CONNECT has released a new SW-Version 2.2.0. Install version 2.2.0 or later to remediate this vulnerability. Schedule the update at your next maintenance window. No workaround offers equivalent protection.
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M is a fixed version for CVE-2025-41733
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M-BM is a fixed version for CVE-2025-41733
  • Firmware 2.2.0 installed on Ethernet-IO EWIO2-BM is a fixed version for CVE-2025-41733
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M is a fixed version for CVE-2025-41734
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M-BM is a fixed version for CVE-2025-41734
  • Firmware 2.2.0 installed on Ethernet-IO EWIO2-BM is a fixed version for CVE-2025-41734
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M is a fixed version for CVE-2025-41735
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M-BM is a fixed version for CVE-2025-41735
  • Firmware 2.2.0 installed on Ethernet-IO EWIO2-BM is a fixed version for CVE-2025-41735
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M is a fixed version for CVE-2025-41736
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M-BM is a fixed version for CVE-2025-41736
  • Firmware 2.2.0 installed on Ethernet-IO EWIO2-BM is a fixed version for CVE-2025-41736
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M is a fixed version for CVE-2025-41737
  • Firmware 2.2.0 installed on Energy-Controlling EWIO2-M-BM is a fixed version for CVE-2025-41737
  • Firmware 2.2.0 installed on Ethernet-IO EWIO2-BM is a fixed version for CVE-2025-41737
For more information see the associated METZ CONNECT GmbH security advisory VDE-2025-097 VDE-2025-097: Metz: Config API – Authentication bypass leads to admin takeover in EWIO2 series - HTML, VDE-2025-097: Metz: Config API – Authentication bypass leads to admin takeover in EWIO2 series - CSAF.
  • November 18, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-322-05
