Nov 18, 2025, 5:33 PM UTC
  • CVSS v4 8.3
  • Vendor: Shelly
  • Equipment: Pro 4PM
  • Vulnerability: Allocation of Resources Without Limits or Throttling
Successful exploitation of this vulnerability could result in a denial-of-service condition.
The following version of Pro 4PM, a smart DIN rail switch, is affected:
  • Pro 4PM: prior to v1.6
3.2.1 ALLOCATION OF RESOURCES WITHOUT LIMITS OR THROTTLING CWE-770
Due to lack of input bounds checking, an attacker can send a specially crafted request to any RPC endpoint. The malicious request causes the device's JSON parser to overallocate memory, leading the device to reboot and creating a denial-of-service condition.
CVE-2025-11243 has been assigned to this vulnerability. A CVSS v3 base score of 7.4 has been calculated; the CVSS vector string is (AV:A/AC:L/PR:N/UI:N/S:C/C:N/I:N/A:H).
A CVSS v4 score has also been calculated for CVE-2025-11243. A base score of 8.3 has been calculated; the CVSS vector string is (AV:A/AC:L/AT:N/PR:N/UI:N/VC:N/VI:N/VA:H/SC:N/SI:N/SA:H).
  • COMPANY HEADQUARTERS LOCATION: Bulgaria
Gabriele Quagliarella of Nozomi Networks reported this vulnerability to CISA.
Shelly did not respond to CISA's attempts at coordination. Users of Shelly Pro 4PM devices are encouraged to contact Shelly and keep their systems up to date, as versions later than 1.6.0 are not vulnerable to the exploit.
  • November 18, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-322-02
