Festo Didactic products
Nov 20, 2025, 5:27 PM UTC
  • CVSS v3 7.8
  • Vendor: Festo SE & Co. KG
  • Equipment: Didactic products
  • Vulnerability: Improper Input Validation
Successful exploitation of this vulnerability could allow the creation or overwriting of arbitrary files in the engineering system.
Festo reports that the following products contain affected versions of Siemens TIA-Portal:
  • Siemens TIA-Portal V15 prior to V17 Update 6 installed on Festo Hardware MES PC: All versions
  • Siemens TIA-Portal V18 prior to V18 Update 1 installed on Festo Hardware MES PC: All versions
  • Siemens TIA-Portal V15 prior to V17 Update 6 installed on Festo Hardware TP260 (
  • Siemens TIA-Portal V18 prior to V18 Update 1 installed on Festo Hardware TP260 (
3.2.1 Improper Input Validation CWE-20
A vulnerability has been identified in Siemens Totally Integrated Automation Portal (TIA Portal) V15, V16, V17, and V18. The affected products contain a path traversal vulnerability that could allow the creation or overwriting of arbitrary files in the engineering system. If the user is tricked into opening a malicious PC system configuration file, an attacker could exploit this vulnerability to achieve arbitrary code execution.
CVE-2023-26293 has been assigned to this vulnerability. A CVSS v3.1 base score of 7.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H).
  • CRITICAL INFRASTRUCTURE SECTORS: Commercial Facilities, Communications, Critical Manufacturing, Energy
Festo coordinated this vulnerability with CERT@VDE.
Festo recommends users of affected devices update TIA-Portal. Refer to Siemens SSA-116924 for more details.
For more information, see the associated Festo SE & Co. KG security advisory FSA-202303 FSA-202303: Festo: Vulnerable Siemens TIA-Portal in multiple Festo Didactic products - HTML and FSA-202303: Festo: Vulnerable Siemens TIA-Portal in multiple Festo Didactic products - CSAF.
CISA recommends users take the following measures to protect themselves from social engineering attacks:
  • November 20, 2025: Initial Republication of Festo FSA-202303
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-324-05
