- CVSS v3 9.8
- ATTENTION: Exploitable remotely/Low attack complexity
- Vendor: Festo
- Equipment: Compact Vision System, Control Block, Controller, and Operator Unit products
- Vulnerabilities: Exposure of Resource to Wrong Sphere, Initialization of a Resource with an Insecure Default
Successful exploitation of these vulnerabilities could result in an attacker accessing devices without authentication or modifying configuration files.
Festo reports that the following products are affected:
- Festo Software Compact Vision System SBO_-Q-_: All Versions
- Festo Software Control block CPX-CEC-C1 Codesys V2: All Versions
- Festo Software Control block CPX-CEC-C1-V3 Codesys V3: All Versions
- Festo Software Control block CPX-CEC Codesys V2: All Versions
- Festo Software Control block CPX-CEC-M1 Codesys V2: All Versions
- Festo Software Control block CPX-CEC-M1-V3 Codesys V3: All Versions
- Festo Software Control block CPX-CEC-S1-V3 Codesys V3: All Versions
- Festo Software Control block CPX-CMXX: All Versions
- Festo Software Controller CECC-D: All Versions
- Festo Software Controller CECC-D-BA: All Versions
- Festo Software Controller CECC-D-CS: All Versions
- Festo Software Controller CECC-LK: All Versions
- Festo Software Controller CECC-S: All Versions
- Festo Software Controller CECC-X-M1: All Versions
- Festo Software Controller CECC-X-M1-MV: All Versions
- Festo Software Controller CECC-X-M1-S1: All Versions
- Festo Software Controller CECX-X-C1: All Versions
- Festo Software Controller CECX-X-M1: All Versions
- Festo Software Controller CPX-E-CEC-C1: All Versions
- Festo Software Controller CPX-E-CEC-C1-EP: All Versions
- Festo Software Controller CPX-E-CEC-C1-PN: All Versions
- Festo Software Controller CPX-E-CEC-M1: All Versions
- Festo Software Controller CPX-E-CEC-M1-EP: All Versions
- Festo Software Controller CPX-E-CEC-M1-PN: All Versions
- Festo Software Controller FED-CEC: All Versions
- Festo Software Operator unit CDPX-X-A-S-10: All Versions
- Festo Software Operator unit CDPX-X-A-W-13: All Versions
- Festo Software Operator unit CDPX-X-A-W-4: All Versions
- Festo Software Operator unit CDPX-X-A-W-7: All Versions
- Festo Software Operator unit CDPX-X-E1-W-10: All Versions
- Festo Software Operator unit CDPX-X-E1-W-15: All Versions
- Festo Software Operator unit CDPX-X-E1-W-7: All Versions
3.2.1 EXPOSURE OF RESOURCE TO WRONG SPHERE CWE-668
A remote, authenticated attacker could utilize the control program of the CODESYS Control runtime system to use the vulnerability in order to read and modify the configuration file(s) of the affected products.
CVE-2022-22515 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.1 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:N).
3.2.2 INITIALIZATION OF A RESOURCE WITH AN INSECURE DEFAULT CWE-1188
In CODESYS V2 PLCWinNT and Runtime Toolkit 32 in versions prior to V2.4.7.57 password protection is not enabled by default and there is no information or prompt to enable password protection at login in case no password is set at the controller.
CVE-2022-31806 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.8 has been calculated; the CVSS vector string is (CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H).
CERT@VDE coordinated and supported publication with Festo. Rob Hulsebos and Daniel dos Santos of Forescout reported this vulnerability to Festo.
Festo has identified the following specific workarounds and mitigations users can apply to reduce risk:
- For CVE-2022-22515: Using the online user management prevents an attacker from downloading and executing malicious code, but also suppresses start, stop, debug, or other actions on a known working application that could potentially disrupt a machine or system.
- For CVE-2022-31806: Enable password protection at login in case no password is set at the controller. Please note that the password configuration file is not covered via default FFT backup & Restore mechanism, you must select the related file manually.
For more information see the associated Festo SE & Co. KG security advisory FSA-202208 FSA-202208: Festo: Multiple Festo products contain an unsafe default Codesys configuration - HTML, FSA-202208: Festo: Multiple Festo products contain an unsafe default Codesys configuration - CSAF.
- November 25, 2025: Initial Republication of Festo SE & Co. KG FSA-202208
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-329-05
