- CVSS v4 8.8
- Vendor: SiRcom
- Equipment: SMART Alert (SiSA)
- Vulnerability: Missing Authentication for Critical Function
Successful exploitation of this vulnerability could enable an attacker to remotely activate or manipulate emergency sirens.
The following versions of SiRcom SMART Alert (SiSA), a central control system, are affected:
- SMART Alert (SiSA): Version 3.0.48
3.2.1 Missing Authentication for Critical Function CWE-306
SiRcom SMART Alert (SiSA) allows unauthorized access to backend APIs. This allows an unauthenticated attacker to bypass the login screen using browser developer tools, gaining access to restricted parts of the application.
CVE-2025-13483 has been assigned to this vulnerability. A CVSS v3.1 base score of 9.1 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-13483. A base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:N/UI:N/VC:N/VI:H/VA:H/SC:N/SI:N/SA:N).
- CRITICAL INFRASTRUCTURE SECTORS: Emergency Services, Government Services and Facilities, Defense Industrial Base
Souvik Kandar of Microsec (microsec.io) reported this vulnerability to CISA.
SiRcom did not respond to CISA's request for coordination. Contact SiRcom using their contact page for more information.
- November 25, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-329-06
