Johnson Controls iSTAR Ultra
Dec 11, 2025, 8:16 PM UTC
  • Vendor: Johnson Controls
  • Equipment: iSTAR Ultra, iSTAR Ultra SE, iSTAR Ultra G2, iSTAR Ultra G2 SE, iSTAR Edge G2, iSTAR Ultra LT
  • Vulnerabilities: OS Command Injection
Successful exploitation of these vulnerabilities could allow an attacker to modify firmware and gain full access to the device.
The following versions of iSTAR Ultra and iSTAR Edge door controllers are affected:
  • iSTAR Ultra: Versions prior to 6.9.7.CU01
  • iSTAR Ultra SE: Versions prior to 6.9.7.CU01
  • iSTAR Ultra LT: Versions prior to 6.9.7.CU01
  • iSTAR Ultra G2: Versions prior to 6.9.3
  • iSTAR Ultra G2 SE: Versions prior to 6.9.3
  • iSTAR Edge G2: Versions prior to 6.9.3
Johnson Controls iSTAR Ultra, Ultra SE, Ultra LT versions prior to 6.9.7.CU01 and Ultra G2, Ultra G2 SE, Edge G2 versions prior to 6.9.3 are vulnerable to OS Command Injection under certain circumstances that could allow an attacker full control of the device.
CVE-2025-43873 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-43873. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
3.2.2 IMPROPER NEUTRALIZATION OF SPECIAL ELEMENTS USED IN AN OS COMMAND ('OS COMMAND INJECTION') CWE-78
CVE-2025-43874 has been assigned to this vulnerability. A CVSS v3.1 base score of 8.8 has been calculated; the CVSS vector string is (AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H).
A CVSS v4 score has also been calculated for CVE-2025-43874. A base score of 8.7 has been calculated; the CVSS vector string is (AV:N/AC:L/AT:N/PR:L/UI:N/VC:H/VI:H/VA:H/SC:N/SI:N/SA:N).
  • CRITICAL INFRASTRUCTURE SECTORS: Critical Manufacturing, Commercial Facilities, Government Services and Facilities, Transportation Systems, Energy
Reid Wightman of Dragos reported these vulnerabilities to CISA.
Johnson Controls recommends users take the following actions:
  • Upgrade iSTAR Ultra, iSTAR Ultra SE, iStar Ultra LT to version 6.9.7.CU01 or greater.
  • Upgrade iSTAR Ultra G2, iSTAR Ultra G2 SE, iSTAR Edge G2 to version 6.9.3 or greater.
  • For more detailed mitigation instructions, please see Johnson Controls Product Security Advisory JCI-PSA-2025-11 and JCI-PSA-2025-13.
  • Johnson Controls recommends taking steps to minimize risks to all building automation systems in alignment with CISA's guidance.
  • Further ICS security notices and product security guidance are located at Johnson Controls product security website.
  • Organizations observing any suspected malicious activity should follow their established internal procedures and report their findings to CISA for tracking and correlation against other incidents.
For more information please contact Johnson Controls Global Product Security or visit their Cybersecurity page.
  • December 11, 2025: Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-25-345-02
