Rockwell Automation 432ES-IG3 Series A
Jan 13, 2026, 5:39 PM UTC
Successful exploitation of this vulnerability could result in a denial-of-service condition.
The following versions of Rockwell Automation 432ES-IG3 Series A are affected:
  • 432ES-IG3 Series A (CVE-2025-9368)
v3 7.5 Rockwell Automation Rockwell Automation 432ES-IG3 Series A Allocation of Resources Without Limits or Throttling
CVE-2025-9368
A security issue exists within 432ES-IG3 Series A, which affects GuardLink EtherNet/IP Interface, resulting in a denial-of-service condition. A manual power cycle is required to recover the device.
Rockwell Automation
Rockwell Automation 432ES-IG3 Series A: V1.001
Rockwell Automation recommends users of 432ES-IG3 Series A update to V2.001.9 or later. The upgrade can be downloaded from the Rockwell Automation website.
Rockwell Automation users using the affected software, who are not able to upgrade to one of the corrected versions, should follow Rockwell Automation's security best practices.
For more information, please review Rockwell Automation's advisory.
  • Rockwell Automation reported this vulnerability to CISA
  • Initial Release Date: 2026-01-13
2026-01-13 1 Initial Republication of Rockwell Automation advisory SD1764
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-013-01
