AVEVA Process Optimization
Jan 15, 2026, 5:40 PM UTC
Successful exploitation of these vulnerabilities could enable an attacker to execute remote code, perform SQL injection, escalate privileges, or access sensitive information.
The following versions of AVEVA Process Optimization are affected:
  • Process Optimization (CVE-2025-61937, CVE-2025-64691, CVE-2025-61943, CVE-2025-65118, CVE-2025-64729, CVE-2025-65117, CVE-2025-64769)
v3 10 AVEVA AVEVA Process Optimization Improper Control of Generation of Code ('Code Injection'), Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection'), Uncontrolled Search Path Element, Missing Authorization, Use of Potentially Dangerous Function, Cleartext Transmission of Sensitive Information
  • Company Headquarters Location: United Kingdom
CVE-2025-61937
The vulnerability, if exploited, could allow an unauthenticated miscreant to achieve remote code execution under OS System privileges of "taoimr" service, potentially resulting in complete compromise of the Model Application Server.
AVEVA
AVEVA Process Optimization: <=2024.1
AVEVA recommends users take the following action:
Update to AVEVA Process Optimization v2025
AVEVA alternatively recommends the following actions users can take to mitigate risk:
Apply Host and/or Network firewall rules restricting the taoimr service to accept traffic only from trusted source(s). By default, AVEVA Process Optimization listens on port 8888/8889(TLS). Please refer to the AVEVA Process Optimization Installation Guide for additional details on ports configuration.
Apply ACLs to the installation and data folders, limiting write-access to trusted users only.
Maintain a trusted chain-of-custody on Process Optimization project files during creation, modification, distribution, backups, and use.
For more information, please Aveva's security bulletin AVEVA-2026-001.
CVE-2025-64691
The vulnerability, if exploited, could allow an authenticated miscreant (OS Standard User) to tamper with TCL Macro scripts and escalate privileges to OS System, potentially resulting in complete compromise of the Model Application Server.
AVEVA
3.1 8.8 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:H
CVE-2025-61943
The vulnerability, if exploited, could allow an authenticated miscreant (Process Optimization Standard User) to tamper with queries in Captive Historian and achieve code execution under SQL Server administrative privileges, potentially resulting in complete compromise of the SQL Server.
AVEVA
Relevant CWE: CWE-89 Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection')
3.1 8.4 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:N/S:C/C:H/I:H/A:N
CVE-2025-65118
The vulnerability, if exploited, could allow an authenticated miscreant (OS Standard User) to trick Process Optimization services into loading arbitrary code and escalate privileges to OS System, potentially resulting in complete compromise of the Model Application Server.
AVEVA
Relevant CWE: CWE-427 Uncontrolled Search Path Element
CVE-2025-64729
The vulnerability, if exploited, could allow an authenticated miscreant (OS Standard User) to tamper with Process Optimization project files, embed code, and escalate their privileges to the identity of a victim user who subsequently interacts with the project files.
AVEVA
Relevant CWE: CWE-862 Missing Authorization
3.1 8.1 HIGH CVSS:3.1/AV:L/AC:L/PR:L/UI:R/S:C/C:H/I:H/A:L
CVE-2025-65117
The vulnerability, if exploited, could allow an authenticated miscreant (Process Optimization Designer User) to embed OLE objects into graphics, and escalate their privileges to the identity of a victim user who subsequently interacts with the graphical elements.
AVEVA
Relevant CWE: CWE-676 Use of Potentially Dangerous Function
3.1 7.4 HIGH CVSS:3.1/AV:L/AC:L/PR:H/UI:R/S:C/C:H/I:H/A:N
CVE-2025-64769
The Process Optimization application suite leverages connection channels/protocols that by-default are not encrypted and could become subject to hijacking or data leakage in certain man-in-the-Middle or passive inspection scenarios.
AVEVA
3.1 7.1 HIGH CVSS:3.1/AV:A/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:L
  • Christopher Wu of Veracode reported these vulnerabilities to AVEVA
  • AVEVA reported these vulnerabilities to CISA
CISA recommends users take defensive measures to minimize the risk of exploitation of this (these) vulnerability(ies), such as:
  • Initial Release Date: 2026-01-15
2026-01-15 1 Initial Republication of AVEVA-2026-001
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-015-01
