Successful exploitation of this vulnerability could enable an attacker to execute arbitrary code.
The following versions of Delta Electronics DIAView are affected:
- DIAView (CVE-2026-0975)
| v3 7.8 | Delta Electronics | Delta Electronics DIAView | Improper Neutralization of Special Elements used in a Command ('Command Injection') |
- Critical Infrastructure Sectors: Chemical, Commercial Facilities, Critical Manufacturing, Energy, Transportation Systems, Water and Wastewater
- Company Headquarters Location: Taiwan
CVE-2026-0975
DIAView functions can execute shell commands within a project script. If an attacker tricks the victim into running a project containing a malicious script, then arbitrary code can be executed when the malicious project starts.
Delta Electronics
Delta Electronics DIAView: 4.2.0
Delta Electronics recommends users update to DIAView v4.4 or later.
For more information, see Delta Electronics advisory Delta-PCSA-2026-00002.
Delta Electronics offers users the following general recommendations:
Do not click on untrusted Internet links or open unsolicited attachments in emails.
Avoid exposing control systems and equipment to the Internet.
Place control system networks and remote devices behind firewalls, and isolate them from the business network.
When remote access is required, use a secure access method, such as a virtual private network (VPN).
If you have any product-related support concerns, contact Delta via the portal page for any information or materials you may require.
Relevant CWE: CWE-77 Improper Neutralization of Special Elements used in a Command ('Command Injection')
| 3.1 | 7.8 | HIGH | CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H |
- An anonymous researcher at Trend Zero Day Initiative reported this vulnerability to CISA
- Initial Release Date: 2026-01-22
| 2026-01-22 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-022-07
