Successful exploitation of these vulnerabilities could allow an attacker to cause a denial-of-service condition.
The following versions of Rockwell Automation ArmorStart LT are affected:
- ArmorStart LT 290D <=V2.002 (CVE-2025-9464, CVE-2025-9465, CVE-2025-9466, CVE-2025-9278, CVE-2025-9279, CVE-2025-9280, CVE-2025-9281, CVE-2025-9282, CVE-2025-9283)
- ArmorStart LT 291D <=V2.002 (CVE-2025-9464, CVE-2025-9465, CVE-2025-9466, CVE-2025-9278, CVE-2025-9279, CVE-2025-9280, CVE-2025-9281, CVE-2025-9282, CVE-2025-9283)
- ArmorStart LT 294D <=V2.002 (CVE-2025-9464, CVE-2025-9465, CVE-2025-9466, CVE-2025-9278, CVE-2025-9279, CVE-2025-9280, CVE-2025-9281, CVE-2025-9282, CVE-2025-9283)
| v3 7.5 | Rockwell Automation | Rockwell Automation ArmorStart LT | Uncontrolled Resource Consumption |
CVE-2025-9464
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. This vulnerability is triggered during fuzzing of multiple CIP classes, which causes the CIP port to become unresponsive.
Rockwell Automation
Rockwell Automation ArmorStart LT 290D: <=V2.002, Rockwell Automation ArmorStart LT 291D: <=V2.002, Rockwell Automation ArmorStart LT 294D: <=V2.002
There is no patch or upgrade at this time. Rockwell Automation recommends users apply security best practices to mitigate the risk of these vulnerabilities.
See Rockwell Automation's SD1768 advisory for more information.
Relevant CWE: CWE-400 Uncontrolled Resource Consumption
CVE-2025-9465
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. During execution of the Achilles Comprehensive grammar tests, the device reboots unexpectedly, causing the Link State Monitor to go down for several seconds.
Rockwell Automation
CVE-2025-9466
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. During execution of the Achilles EtherNet/IP and CIP grammar tests, the device reboots unexpectedly, causing the Link State Monitor to go down for several seconds.
Rockwell Automation
CVE-2025-9278
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. After running a Burp Suite active scan, the device loses ICMP connectivity, causing the web application to become inaccessible.
Rockwell Automation
CVE-2025-9279
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. During execution of the Achilles EtherNet/IP Step Limit Storm tests, the device reboots unexpectedly, causing the Link State Monitor to go down for several seconds.
Rockwell Automation
CVE-2025-9280
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. Fuzzing performed using Defensics causes the device to become unresponsive, requiring a reboot.
Rockwell Automation
CVE-2025-9281
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. During execution of the Achilles Comprehensive step limit storm tests, the device reboots unexpectedly, causing the Link State Monitor to go down for several seconds.
Rockwell Automation
CVE-2025-9282
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. During execution of the Achilles Comprehensive limited storm tests, the device reboots unexpectedly, causing the Link State Monitor to go down for several seconds.
Rockwell Automation
CVE-2025-9283
A security issue exists within ArmorStart® LT that can result in a denial-of-service condition. During execution of the Achilles EtherNet/IP Step Limits Storms tests, the device reboots unexpectedly, causing the Link State Monitor to go down for several seconds.
Rockwell Automation
- Rockwell Automation reported these vulnerabilties to CISA
- Initial Release Date: 2026-01-29
| 2026-01-29 | 1 | Initial Republication of Rockwell Automation advisory SD1768 |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-029-02
