Successful exploitation of this vulnerability may allow an attacker to write arbitrary data beyond the bounds of a stack-allocated buffer, leading to the corruption of a structured exception handler (SEH).
The following versions of Delta Electronics ASDA-Soft are affected:
- ASDA-Soft <=7.2.0.0 (CVE-2026-1361)
| v3 7.8 | Delta Electronics | Delta Electronics ASDA-Soft | Stack-based Buffer Overflow |
- Company Headquarters Location: Taiwan
CVE-2026-1361
A stack-based buffer overflow vulnerability exists in ASDA_Soft version 7.2.0.0 when parsing .par files. The root cause is the improper validation of a user-controlled size parameter, which is checked incorrectly against the upper limits of the local buffer. This allows data to be written past the end of the buffer.
Delta Electronics
Delta Electronics ASDA-Soft: <=7.2.0.0
Delta has fixed this vulnerability and released a new version v7.2.2.0 at Delta Download Center (https://downloadcenter.deltaww.com/en-US/DownloadCenter?v=1&q=asda-soft&sort_expr=cdate&sort_dir=DESC).
For more information, see Delta Electronics advisory Delta-PCSA-2026-00003 at https://www.deltaww.com/en-US/service-support/product-cybersecurity/advisory
Delta Electronics provides the following general recommendations: Do not click on untrusted internet links or open unsolicited attachments in emails. Avoid exposing control systems and equipment to the Internet. Place control system networks and remote devices behind firewalls, and isolate them from the business network. When remote access is required, use a secure access method, such as a virtual private network (VPN).
If you have any product-related support concerns, contact Delta via the portal page(https://www.deltaww.com/en-US/service-support/contact-us?type=1) for any information or materials you may require.
| 3.1 | 7.8 | HIGH | CVSS:3.1/AV:L/AC:L/PR:N/UI:R/S:U/C:H/I:H/A:H |
- nisu of Trend Research reported this vulnerability to CISA
- Initial Release Date: 2026-02-17
| 2026-02-17 | 1 | Initial Publication. |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-048-02
