Successful exploitation of these vulnerabilities could result in authentication being disabled, a denial-of-service condition, or an attacker stealing valid user credentials, including administrator credentials.
The following versions of Jinan USR IOT Technology Limited (PUSR) USR-W610 are affected:
- USR-W610 <=3.1.1.0 (CVE-2026-25715, CVE-2026-24455, CVE-2026-26049, CVE-2026-26048)
| v3 9.8 | Jinan USR IOT Technology Limited (PUSR) | Jinan USR IOT Technology Limited (PUSR) USR-W610 | Weak Password Requirements, Cleartext Transmission of Sensitive Information, Insufficiently Protected Credentials, Missing Authentication for Critical Function |
- Company Headquarters Location: China
CVE-2026-25715
The web management interface of the device allows the administrator username and password to be set to blank values. Once applied, the device permits authentication with empty credentials over the web management interface and Telnet service. This effectively disables authentication across all critical management channels, allowing any network-adjacent attacker to gain full administrative control without credentials.
Jinan USR IOT Technology Limited (PUSR) USR-W610: <=3.1.1.0
Jinan USR IOT Technology Limited (PUSR) has stated that the product is end-of-life, and there are no plans to patch. Users of PUSR USR-W610 devices are encouraged to contact PUSR and keep their systems up to date.
Relevant CWE: CWE-521 Weak Password Requirements
CVE-2026-24455
The embedded web interface of the device does not support HTTPS/TLS for authentication and uses HTTP Basic Authentication. Traffic is encoded but not encrypted, exposing user credentials to passive interception by attackers on the same network.
| 3.1 | 7.5 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N |
CVE-2026-26049
The web management interface of the device renders the passwords in a plaintext input field. The current password is directly visible to anyone with access to the UI, potentially exposing administrator credentials to unauthorized observation via shoulder surfing, screenshots, or browser form caching.
| 3.1 | 5.7 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:L/UI:R/S:U/C:H/I:N/A:N |
CVE-2026-26048
The Wi-Fi router is vulnerable to de-authentication attacks due to the absence of Management Frame Protection, allowing forged deauthentication and disassociation frames to be broadcast without authentication or encryption. An attacker can use this to cause unauthorized disruptions and create a denial-of-service condition.
- Abhishek Pandey of Payatu Security Consulting reported CVE-2026-25715, CVE-2026-24455, and CVE-2026-26049 to CISA
- Abhishek Pandey and Ranit Pradhan of Payatu Security Consulting reported CVE-2026-26048 to CISA
- Initial Release Date: 2026-02-19
| 2026-02-19 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-050-03
