Schneider Electric is aware of a vulnerability in EcoStruxure Building Operation Workstation and EcoStruxure Building Operation WebStation. [EcoStruxure Building Operation (EBO)](https://www.se.com/ww/en/product-range/62111-ecostruxure-building-operation-software/#overview) is an open and scalable software platform providing insight, control and management of multiple building systems and devices in one mobile-enabled convenient view. It delivers valuable data for decision-making to improve energy management and increase efficiency for better building performance and comfort, reduced carbon, and more sustainable building environments. Failure to apply the remediations below may risk exposure of local files or denial of service, which could result in data breaches, and operational disruptions.
The following versions of Schneider Electric EcoStruxure Building Operation Workstation are affected:
- EcoStruxure Building Operation Workstation vers:generic/>=7.0.x|<7.0.3.2000_(CP1), 7.0.3.2000_CP1, vers:generic/>=6.x|<6.0.4.14001_(CP10), 6.0.4.14001_CP10, vers:intdot/>=7.0.x|<7.0.2, 7.0.2, vers:generic/>=6.0.x|<6.0.4.7000_(CP5), 6.0.4.7000_CP5 (CVE-2026-1227, CVE-2026-1227, CVE-2026-1226, CVE-2026-1226)
- EcoStruxure Building Operation WebStation vers:generic/>=7.0.x|<7.0.3.2000_(CP1), 7.0.3.2000_CP1, vers:generic/>=6.x|<6.0.4.14001_(CP10), 6.0.4.14001_CP10, vers:intdot/>=7.0.x|<7.0.2, 7.0.2, vers:generic/>=6.0.x|<6.0.4.7000_(CP5), 6.0.4.7000_CP5 (CVE-2026-1227, CVE-2026-1227, CVE-2026-1226, CVE-2026-1226)
| v3 7.3 | Schneider Electric | Schneider Electric EcoStruxure Building Operation Workstation | Improper Restriction of XML External Entity Reference, Improper Control of Generation of Code ('Code Injection') |
- Critical Infrastructure Sectors: Commercial Facilities, Energy, Government Services and Facilities, Healthcare and Public Health, Information Technology, Transportation Systems, Financial Services, Defense Industrial Base, Critical Manufacturing
- Company Headquarters Location: France
CVE-2026-1227
An improper restriction of XML external entity reference vulnerability exists that could result in unauthorized disclosure of local files, unauthorized interaction with the EBO system, or denial-of-service conditions. This occurs when a local user uploads a maliciously crafted TGML graphics file to the EBO server from Workstation.
Schneider Electric
EcoStruxure Building Operation Workstation All 7.0.x versions prior to 7.0.3.2000 (CP1), EcoStruxure Building Operation Workstation All 6.x versions prior to 6.0.4.14001 (CP10), EcoStruxure Building Operation WebStation All 7.0.x versions prior to 7.0.3.2000 (CP1), EcoStruxure Building Operation WebStation All 6.x versions prior to 6.0.4.14001 (CP10)
fixed, known_affected
The following versions of EcoStruxure Building Operation Workstation and EcoStruxure Building Operation WebStation include a fix for CVE-2026-1227: • 7.0.3.2000 (CP1) Step 1: Navigate to this link: https://www.se.com/myschneider/documentsDownloadCenter/detail?id=EBO-Patch-v7-0 Step 2: Download 'EcoStruxure Building Operation Patch v7.0' Step 3: Follow the installation instructions provided in the accompanying readme file. Additionally, ensure you are following the [EBO hardening guidelines](https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=14923&productversion=7.1&locale=en-US).
The following versions of EcoStruxure Building Operation Workstation and EcoStruxure Building Operation WebStation includes a fix for CVE-2026-1227: • 6.0.4.14001 (CP10) Step 1: Locate the appropriate version for your system here: https://www.se.com/myschneider/documentsDownloadCenter/detail?id=EBO-Patch-v6-0 Step 2: Download ‘EcoStruxure Building Operation Patch v6.0‘ Step 3: Follow the installation instructions provided in the accompanying readme file. Additionally, ensure you are following the [EBO hardening guidelines](https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=14923&productversion=7.1&locale=en-US).
If customers choose not to apply the remediation provided above, they should immediately apply the following mitigations to reduce the risk of exploit: • Implement strong access controls to limit system access to authorized personnel. • Use multi factor authentication if using EBO version 7.0 or later. • Use firewalls to segregate networks and protect the building management system. • Regularly monitor system activity. • Ensure you are following [EBO hardening guidelines](https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=14923&productversion=7.1&locale=en-US).
For more information see the associated Schneider Electric security advisory SEVD-2026-041-02, titled ‘Multiple Vulnerabilities on EcoStruxure Building Operation Workstation and EcoStruxure Building Operation WebStation‘. • PDF Version: [https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=SEVD-2026-041-02.pdf](https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=SEVD-2026-041-02.pdf) • CSAF Version: [https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=sevd-2026-041-02.json](https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=sevd-2026-041-02.json).
Relevant CWE: CWE-611 Improper Restriction of XML External Entity Reference
| 3.1 | 7.3 | HIGH | CVSS:3.1/AV:L/AC:L/PR:L/UI:R/S:U/C:H/I:H/A:H |
CVE-2026-1226
An improper control of generation of code vulnerability exists that could result in the execution of untrusted or unintended code within the application. This occurs when maliciously crafted design content is processed through a TGML graphics file.
Schneider Electric
EcoStruxure Building Operation Workstation All 7.0.x versions prior to 7.0.2, EcoStruxure Building Operation Workstation All 6.0.x versions prior to 6.0.4.7000 (CP5), EcoStruxure Building Operation Webstation All 7.0.x versions prior to 7.0.2, EcoStruxure Building Operation Webstation All 6.0.x versions prior to 6.0.4.7000 (CP5)
The following versions of EcoStruxure Building Operation Workstation and EcoStruxure Building Operation WebStation include a fix for CVE-2026-1226: • 7.0.2 Step 1: Navigate to this link: https://www.se.com/myschneider/documentsDownloadCenter/detail?id=EBO-Patch-v7-0 Step 2: Download 'EcoStruxure Building Operation Patch v7.0' Step 3: Follow the installation instructions provided in the accompanying readme file. Additionally, ensure you are following the [EBO hardening guidelines](https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=14923&productversion=7.1&locale=en-US).
The following versions of EcoStruxure Building Operation Workstation and EcoStruxure Building Operation WebStation includes a fix for CVE-2026-1226: • 6.0.4.7000 (CP5) Step 1: Locate the appropriate version for your system here: https://www.se.com/myschneider/documentsDownloadCenter/detail?id=EBO-Patch-v6-0 Step 2: Download ‘EcoStruxure Building Operation Patch v6.0‘ Step 3: Follow the installation instructions provided in the accompanying readme file. Additionally, ensure you are following the [EBO hardening guidelines](https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=14923&productversion=7.1&locale=en-US).
For more information see the associated Schneider Electric security advisory SEVD-2026-041-02, titled "Multiple Vulnerabilities on EcoStruxure Building Operation Workstation and EcoStruxure Building Operation WebStation". • PDF Version: [https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=SEVD-2026-041-02.pdf](https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=SEVD-2026-041-02.pdf) • CSAF Version: [https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=sevd-2026-041-02.json](https://download.schneider-electric.com/files?p_Doc_Ref=SEVD-2026-041-02&p_enDocType=Security+and+Safety+Notice&p_File_Name=sevd-2026-041-02.json).
- Pentest Limited reported these vulnerabilities to Schneider Electric.
- Robin Plugge reported these vulnerabilities to Schneider Electric.
We strongly recommend the following industry cybersecurity best practices. * Locate control and safety system networks and remote devices behind firewalls and isolate them from the business network. * Install physical controls so no unauthorized personnel can access your industrial control and safety systems, components, peripheral equipment, and networks. * Place all controllers in locked cabinets and never leave them in the “Program” mode. * Never connect programming software to any network other than the network intended for that device. * Scan all methods of mobile data exchange with the isolated network such as CDs, USB drives, etc. before use in the terminals or any node connected to these networks. * Never allow mobile devices that have connected to any other network besides the intended network to connect to the safety or control networks without proper sanitation. * Minimize network exposure for all control system devices and systems and ensure that they are not accessible from the Internet. * When remote access is required, use secure methods, such as Virtual Private Networks (VPNs). Recognize that VPNs may have vulnerabilities and should be updated to the most current version available. Also, understand that VPNs are only as secure as the connected devices. For more information refer to the Schneider Electric [Recommended Cybersecurity Best Practices](https://www.se.com/us/en/download/document/7EN52-0390/) document.
For More Information
This document provides an overview of the identified vulnerability or vulnerabilities and actions required to mitigate. For more details and assistance on how to protect your installation, contact your local Schneider Electric representative or Schneider Electric Industrial Cybersecurity Services: https://www.se.com/ww/en/work/solutions/cybersecurity/. These organizations will be fully aware of this situation and can support you through the process. For further information related to cybersecurity in Schneider Electric's products, visit the company's cybersecurity support portal page: https://www.se.com/ww/en/work/support/cybersecurity/overview.jsp
LEGAL DISCLAIMER
About Schneider Electric
Schneider's purpose is to create Impact by empowering all to make the most of our energy and resources, bridging progress and sustainability for all. We call this Life Is On. Our mission is to be the trusted partner in sustainability and efficiency. We are a global industrial technology leader bringing world-leading expertise in electrification, automation and digitization to smart industries, resilient infrastructure, future-proof data centers, intelligent buildings, and intuitive homes. Anchored by our deep domain expertise, we provide integrated end-to-end lifecycle AI enabled Industrial IoT solutions with connected products, automation, software and services, delivering digital twins to enable profitable growth for our customers. We are a people company with an ecosystem of 150,000 colleagues and more than a million partners operating in over 100 countries to ensure proximity to our customers and stakeholders. We embrace diversity and inclusion in everything we do, guided by our meaningful purpose of a sustainable future for all. www.se.com
CISA recommends users take defensive measures to minimize the exploitation risk of this vulnerability: * Minimize network exposure for all control system devices and/or systems, and ensure they are not accessible from the internet. * Locate control system networks and remote devices behind firewalls and isolate them from business networks. * When remote access is required, use more secure methods, such as virtual private networks (VPNs), recognizing VPNs may have vulnerabilities and should be updated to the most recent version available. Also recognize VPN is only as secure as its connected devices.
CISA also provides a section for control systems security recommended practices on the ICS webpage on cisa.gov. Several CISA products detailing cyber defense best practices are available for reading and download, including Improving Industrial Control Systems Cybersecurity with Defense-in-Depth Strategies. (https://us-cert.cisa.gov/sites/default/files/recommended_practices/NCCIC_ICS-CERT_Defense_in_Depth_2016_S508C.pdf)
CISA encourages organizations to implement recommended cybersecurity strategies for proactive defense of ICS assets. Additional mitigation guidance and recommended practices are publicly available on the ICS webpage at cisa.gov in the technical information paper, ICS-TIP-12-146-01B--Targeted Cyber Intrusion Detection and Mitigation Strategies. (https://www.cisa.gov/sites/default/files/publications/Cybersecurity_Best_Practices_for_Industrial_Control_Systems.pdf)
This ICSA is a verbatim republication of Schneider Electric SEVD-2026-041-02 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact Schneider Electric directly for any questions regarding this advisory.
| 2026-02-10 | 1 | Original Release |
| 2026-02-24 | 2 | Initial CISA Republication of Schneider Electric SEVD-2026-041-02 advisory |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-055-02
