The following versions of Mobility46 mobility46.se are affected:
- mobility46.se vers:all/* (CVE-2026-27028, CVE-2026-26305, CVE-2026-27647, CVE-2026-22878)
| v3 9.4 | Mobility46 | Mobility46 mobility46.se | Missing Authentication for Critical Function, Improper Restriction of Excessive Authentication Attempts, Insufficient Session Expiration, Insufficiently Protected Credentials |
- Critical Infrastructure Sectors: Energy, Transportation Systems
- Company Headquarters Location: Sweden
CVE-2026-27028
Mobility46
Mobility46 mobility46.se: vers:all/*
Mobility46 did not respond to CISA's request for coordination. Contact Mobility46 using their contact page here: https://www.mobility46.se/en/contact-us for more information.
| 3.1 | 9.4 | CRITICAL | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:L |
CVE-2026-26305
Mobility46
CVE-2026-27647
Mobility46
| 3.1 | 7.3 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:L |
CVE-2026-22878
Mobility46
| 3.1 | 6.5 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:L/A:N |
- Khaled Sarieddine and Mohammad Ali Sayed reported these vulnerabilities to CISA
- Initial Release Date: 2026-02-26
| 2026-02-26 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-057-08
