Successful exploitation of this vulnerability could result in arbitrary file upload to the target equipment.
The following versions of Ceragon Siklu MultiHaul and EtherHaul Series are affected:
- MultiHaul MH-B100-CCS
- MultiHaul MH-T200-CCC
- MultiHaul MH-T200-CNN
- MultiHaul MH-T201-CNN
- EtherHaul EH-8010FX
- EtherHaul EH-500TX
- EtherHaul EH-600TX
- EtherHaul EH-614TX
- EtherHaul EH-700TX
- EtherHaul EH-710TX
- EtherHaul EH-1200TX
- EtherHaul EH-1200FX
- EtherHaul EH-2200FX
- EtherHaul EH-2500FX
- EtherHaul EH-5500FD
| v3 5.3 | Ceragon | Ceragon Siklu MultiHaul and EtherHaul Series | Unrestricted Upload of File with Dangerous Type |
- Critical Infrastructure Sectors: Communications
- Company Headquarters Location: Israel
CVE-2025-57176
The rfpiped service on TCP port 555 in Ceragon Networks / Siklu Communication EtherHaul and MultiHaul Series microwave antennas allow unauthenticated file uploads to any writable location on the device. File upload packets use weak encryption (metadata only) with file contents transmitted in cleartext. No authentication or path validation is performed.
Ceragon
Ceragon MultiHaul MH-B100-CCS:
Ceragon has released a software update for the affected models:
Affected users should install firmware version R2.4.0 for affected MultiHaul models.
Affected users should install firmware version R10.8.1 for the affected EH-8010FX model.
Affected users should install firmware version R7.7.12 for other affected EtherHaul models.
Additionally Ceragon has provided the following security recommendations for mitigating the listed vulnerability. To prevent exposure, management access must follow standard operator security guidelines:
Management IP addresses must use private subnets (RFC 1918)
Management networks must be protected by: *-* Firewalls *-* Access Control Lists *-* Network Access Translation / Secure management domains
Firewalls
Public exposure of management IP Addresses is not supported nor recommendedCeragon requests that affected users please verify that all affected radio units:
Use private management IP addresses only
Are placed behind internal security controls
Follow your organization's authentication and access-control policies
Please visit the Ceragon portal here: https://portal.ceragon.com/ (login required) for further information.
Relevant CWE: CWE-434 Unrestricted Upload of File with Dangerous Type
| 3.1 | 5.3 | MEDIUM | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:L/I:N/A:N |
- CISA discovered a public Proof of Concept (PoC) as authored by semaja22 and reported it to Ceragon
CISA recommends users take defensive measures to minimize the risk of exploitation of this (these) vulnerability(ies), such as:
- Initial Release Date: 2026-03-10
| 2026-03-10 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-069-04
