Inductive Automation Ignition Software
Mar 12, 2026, 4:07 PM UTC
Successful exploitation of this vulnerability could allow an attacker to execute malicious code with OS application service account permissions that the authenticated, privileged application user did not intend on running.
The following versions of Inductive Automation Ignition Software are affected:
  • Ignition Software <8.3.0 (CVE-2025-13913)
v3 6.3 Inductive Automation Inductive Automation Ignition Software Deserialization of Untrusted Data
  • Critical Infrastructure Sectors: Information Technology
CVE-2025-13913
A privileged Ignition user, intentionally or otherwise, imports an external file with a specially crafted payload, which executes embedded malicious code during deserialization.
Inductive Automation Ignition Software: <8.3.0
Fix - upgrade Ignition software from 8.1.x to 8.3.0 or greater.
MITIGATION (8.1.x Linux). Implement Ignition Security Hardening Guide Appendix A. https://inductiveautomation.com/resources/article/ignition-security-hardening-guide
MITIGATION (8.1.x Windows). Covered in Ignition Security Hardening Guide Appendix A. 1. Create a new dedicated local Windows account that will be used exclusively for the Ignition service (e.g. svc-ign). a. The best security practice is that the Ignition service should not be a domain account (unless otherwise needed). b. Remove all group memberships from the service account (including Users and Administrators). c. Add to security policy to log in as a service. d. Add to "Deny log on locally" security policy. 2. Provide full read/write access only to the Ignition installation directory for the service account created in #1. a. Add read/write permissions to other directories in the local filesystem as needed (e.g.: if configured to use optional Enterprise Administration Module to write automated backups to the file system). 3. Set deny access settings for service account on other directories not needed by the Ignition service. a. Specifically the C:\Windows, C:\Users, and directories for any other applications in the Program Files or Program Files(x86) directories. b. Use java param to change temp directory to a location within the Ignition install directory so the Users folder can be denied access to the Ignition service account.
BEST PRACTICES (8.1.x and 8.3.x)4. Restrict project imports to verified and trusted sources only, ideally using checksums or digital signatures.5. Use multiple environments (e.g. Dev, Test, Prod) with a staging workflow so that new data is never introduced directly to Production environments. See Ignition Deployment Best Practices.6. When feasible, segment or isolate Ignition gateways from corporate resources and Windows Domains.a. The Ignition service account or AD server object should never need Windows Domain or Windows Active Directory privileges. This would only be needed if an Asset Owners IT or OT department uses this for management outside Ignition.b. Ignition may be federated with Active Directory environments (e.g. OT domains) by entering "Authentication Profile" credentials within the Ignition gateway itself. This could use secure LDAP, SAML, or OpenID Connect.7. When feasible, enforce strong credential management and MFA for all users with Designer permissions (8.1.x and 8.3.x), Config Page permissions (8.1.x), and Config Write permissions (8.3.x).8. When feasible, deploy Ignition within hardened or containerized environments.
Relevant CWE: CWE-502 Deserialization of Untrusted Data
3.1 6.3 MEDIUM CVSS:3.1/AV:A/AC:H/PR:H/UI:R/S:U/C:H/I:H/A:H
  • Nik Tsytsarkin, Ismail Aydemir, and Ryan Hall of Meta reported this vulnerability to Inductive Automation
  • Nathan Boeger and Joel Specht of Inductive Automation ([email protected]) reported this vulnerability to CISA
  • Initial Release Date: 2026-03-12
2026-03-12 1 Initial Publication
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-071-06
