Successful exploitation of this vulnerability could allow an attacker to bypass authentication and have remote access to sensitive information on the device.
The following versions of Hangzhou Xiongmai Technology Co., Ltd XM530 IP Camera are affected:
- IP Camera XM530V200_X6-WEQ_8M firmware V5.00.R02.000807D8.10010.346624.S.ONVIF_21.06 (CVE-2025-65856)
| v3 9.8 | Hangzhou Xiongmai Technology Co., Ltd | Hangzhou Xiongmai Technology Co., Ltd XM530 IP Camera | Missing Authentication for Critical Function |
- Critical Infrastructure Sectors: Commercial Facilities
- Company Headquarters Location: China
CVE-2025-65856
Authentication bypass vulnerability in Xiongmai XM530 IP cameras on Firmware V5.00.R02.000807D8.10010.346624.S.ONVIF 21.06 allows unauthenticated remote attackers to access sensitive device information and live video streams. The ONVIF implementation fails to enforce authentication on 31 critical endpoints, enabling direct unauthorized video stream access.
Hangzhou Xiongmai Technology Co., Ltd IP Camera XM530V200_X6-WEQ_8M firmware: V5.00.R02.000807D8.10010.346624.S.ONVIF_21.06
Hangzhou Xiongmai Technology Co., Ltd has not responded to requests to work with CISA to mitigate this vulnerability. Users of affected versions of XM530 IP cameras are invited to contact Xiongmai Technology customer support for additional information (https://www.xiongmaitech.com/en/index.php/about/contact/42).
- CISA discovered a public Proof of Concept (PoC) as authored by Luis Miranda Acebedo and reported it to MITRE
- Initial Release Date: 2026-04-23
| 2026-04-23 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-113-05
