Successful exploitation of these vulnerabilities could allow an attacker to disclose sensitive information.
The following versions of SpiceJet Online Booking System are affected:
- Online Booking System vers:all/* (CVE-2026-6375, CVE-2026-6376)
| v3 7.5 | SpiceJet | SpiceJet Online Booking System | Authorization Bypass Through User-Controlled Key, Missing Authentication for Critical Function |
- Critical Infrastructure Sectors: Transportation Systems
- Company Headquarters Location: India
CVE-2026-6375
A vulnerability in SpiceJet's booking API allows unauthenticated users to query passenger name records (PNRs) without any access controls. Because PNR identifiers follow a predictable pattern, an attacker could systematically enumerate valid records and obtain associated passenger names. This flaw stems from missing authorization checks on an endpoint intended for authenticated profile access.
SpiceJet
SpiceJet Online Booking System: vers:all/*
SpiceJet did not respond to CISA's requests to coordinate. Users are encouraged to reach out to SpiceJet for more information: https://corporate.spicejet.com/contactus.aspx
Relevant CWE: CWE-639 Authorization Bypass Through User-Controlled Key
| 3.1 | 7.5 | HIGH | CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N |
CVE-2026-6376
A weakness in SpiceJet's public booking retrieval page permits full passenger booking details to be accessed using only a PNR and last name, with no authentication or verification mechanisms. This results in exposure of extensive personal, travel, and booking metadata to any unauthenticated user who can obtain or guess those basic inputs. The issue arises from improper access control on a sensitive data retrieval function.
SpiceJet
- Owais Shaikh reported these vulnerabilities to CISA
- Initial Release Date: 2026-04-23
| 2026-04-23 | 1 | Initial Publication |
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-113-04
