ABB Ability Symphony Plus Engineering
Apr 30, 2026, 3:57 PM UTC
ABB became aware of vulnerability in the products versions listed as affected in the advisory. The ABB S+ Engineering product versions are affected by vulnerabilities in PostgreSQL version 13.11 and earlier versions. If an attacker gains access to a site’s S+ Client Server network, they could exploit such vulnerabilities by executing arbitrary code and potentially compromising the entire system.
The following versions of ABB Ability Symphony Plus Engineering are affected:
  • Ability Symphony Plus 2.2, 2.3, 2.3_RU1, 2.3_RU2, 2.3_RU3, 2.4, 2.4_SP1, 2.4_SP2, 2.4_SP2_RU1
v3 8.8 ABB ABB Ability Symphony Plus Engineering Integer Overflow or Wraparound, Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection'), Time-of-check Time-of-use (TOCTOU) Race Condition, Privilege Dropping / Lowering Errors
  • Critical Infrastructure Sectors: Chemical, Critical Manufacturing, Energy, Water and Wastewater
CVE-2023-5869
An attacker running as an authenticated PostgreSQL user can provide crafted data and trigger the integer overflow due to such missing overflow check. This can enable the execution of arbitrary code in the system.
ABB
ABB Ability Symphony Plus S+ Engineering 2.2, ABB Ability Symphony Plus S+ Engineering 2.3, ABB Ability Symphony Plus S+ Engineering 2.3 RU1, ABB Ability Symphony Plus S+ Engineering 2.3 RU2, ABB Ability Symphony Plus S+ Engineering 2.3 RU3, ABB Ability Symphony Plus S+ Engineering 2.4, ABB Ability Symphony Plus S+ Engineering 2.4 SP1, ABB Ability Symphony Plus S+ Engineering 2.4 SP2
fixed, known_affected
ABB advises all customers to review their installations to determine if they are using an impacted product as listed above, no further analysis or tools are needed to make this determination. The recommended immediate actions per product are listed below: - Systems using S+ Engineering 2.2 through 2.4 SP2 should upgrade to S+ Engineering 2.4 SP2 RU1 (re-leased in December 2024) or later. - End users who are unable to install one of these updates should immediately look to implement the Mitigation and Workarounds listed below as this will restrict or prevent an attacker’s ability to com-promise the system. ABB recommends that customers apply the update at the earliest convenience.
Any exploit of these vulnerabilities would require that the attacker has access to the site’s S+ client/server network. Following ABB’s recommended security practices, including network architecture and perimeter firewall, are mitigating factors in preventing external access to the S+ client/server net-work. Refer to section “General security recommendations” for further advise on how to keep your system secure.
Workaround
No workarounds are available. Assess the installation specific risk based on this advisory. Use the recommendations described under “Mitigating factors” or “Recommended immediate actions”.
Relevant CWE: CWE-190 Integer Overflow or Wraparound
3.1 8.8 HIGH CVSS:3.1/AV:N/AC:L/PR:L/UI:N/S:U/C:H/I:H/A:H/E:F/RL:U/RC:C
CVE-2023-39417
If an administrator has installed Extension scripts and specific data is used inside a quoting con-struct, an attacker having proper PostgreSQL privileges can execute arbitrary code in the system as the administrator.
ABB
Workaround
Relevant CWE: CWE-89 Improper Neutralization of Special Elements used in an SQL Command ('SQL Injection')
3.1 7.5 HIGH CVSS:3.1/AV:N/AC:H/PR:L/UI:N/S:U/C:H/I:H/A:H/E:F/RL:U/RC:C
CVE-2024-7348
A ‘time-of-check time-of-use’ (TOCTOU) race condition in a PostgreSQL can allow an attacker to easily execute arbitrary SQL functions by leveraging a PostgreSQL utility often executed with high privileges.
ABB
Workaround
Relevant CWE: CWE-367 Time-of-check Time-of-use (TOCTOU) Race Condition
CVE-2024-0985
An attacker can provide untrusted materialized views and lure a high privileged authorized user to inadvertently execute arbitrary SQL functions by refreshing the attacker's materialized view.
ABB
Workaround
Relevant CWE: CWE-271 Privilege Dropping / Lowering Errors
3.1 8 HIGH CVSS:3.1/AV:N/AC:L/PR:L/UI:R/S:U/C:H/I:H/A:H/E:F/RL:U/RC:C
  • ABB Global reported these vulnerabilities to CISA.
Notice
The information in this document is subject to change without notice, and should not be construed as a commitment by ABB. ABB provides no warranty, express or implied, including warranties of merchantability and fitness for a particular purpose, for the information contained in this document, and assumes no responsibility for any errors that may appear in this document. In no event shall ABB or any of its suppliers be liable for direct, indirect, special, incidental or consequential damages of any nature or kind arising from the use of this document, or from the use of any hardware or software described in this document, even if ABB or its suppliers have been advised of the possibility of such damages. This document and parts hereof must not be reproduced or copied without written permission from ABB, and the contents hereof must not be imparted to a third party nor used for any unauthorized purpose. All rights to registrations and trademarks reside with their respective owners.
Frequently Asked Questions
What is the scope of the vulnerability? - An attacker who successfully exploited these vulnerabilities could insert and run arbitrary code in the S+ system. What causes the vulnerability? - It is caused by several vulnerabilities in the PostgreSQL version 13.11 and earlier versions component used by the S+ Engineering product (see Affected products). What might an attacker use the vulnerability to do? - An attacker who successfully accessed the site’s S+ client/server network could cause a denial-of-service situation, corruptions of data or unauthorized disclosure of information. How could an attacker exploit the vulnerability? - To exploit the PostgreSQL vulnerabilities (see Vulnerability severity and details), an attacker should successfully access to the site’s S+ client/server network, remotely (through a wrongly configured or penetrated firewall) or even compromising a local machine and then accessing to PostgreSQL. Recommended practices help mitigate such attacks, see section Mitigating Factors above. Could the vulnerability be exploited remotely? - Yes, see the above How could an attacker exploit the vulnerability? Recommended practices include that process control systems are physically protected, have no direct connections to the Internet, and are separated from other networks by means of a firewall system that has a minimal number of ports exposed. Can functional safety be affected by an exploit of this vulnerability? - Functional safety systems are not affected by these vulnerabilities What does the update do? - The S+ Engineering update removes the vulnerability by installing a secure updated PostgreSQL version. When this security advisory was issued, had this vulnerability been publicly disclosed? - Yes, PostgreSQL 13.11 vulnerabilities have been publicly disclosed. When this security advisory was issued, had ABB received any reports that this vulnerability was being exploited? - No, ABB had not received any information indicating that S+ Engineering had been exploited when this security advisory was originally issued.
This ICSA is a verbatim republication of ABB PSIRT 7PAA017341 from a direct conversion of the vendor's Common Security Advisory Framework (CSAF) advisory. This is republished to CISA's website as a means of increasing visibility and is provided "as-is" for informational purposes only. CISA is not responsible for the editorial or technical accuracy of republished advisories and provides no warranties of any kind regarding any information contained within this advisory. Further, CISA does not endorse any commercial product or service. Please contact ABB PSIRT directly for any questions regarding this advisory.
  • Initial Release Date: 2026-04-13
2026-04-13 1 Initial version.
2026-04-30 2 Initial CISA Republication of ABB PSIRT 7PAA017341 advisory
This is a companion discussion topic for the original entry at https://www.cisa.gov/news-events/ics-advisories/icsa-26-120-06
